[Guide] Gigabyte B360 Aorus Gaming 3 WiFi - Intel Core i5 9400F - RX580
that's fine as a blogger i can understand your situation, just want let you know i tried many methods on this week, list given below :
Nothing works for me, is anything wrong with the MBoard we choose or any particular way for this board to activate iMessage?
I'll try to write the guide very soon. The issue is with the MLB, ROM. That's the important part.
I have a very similar configuration but I'm having issues to boot into the Catalina Installer.
This is my Desktop configuration:
Motherboard : Gigabyte B360M AORUS Gaming 3 rev 1.0 (Not the WIFI version)
CPU: Intel Core i5 - 9600KF
RAM: Corsair ballistix 32 GB 3200MHz
IGPU: None
Graphics: AsRock Radeon RX 5500 XT 4GB
SSD: Adata XPG SX6000, 1TB, M.2 NVMe
HD: Sata Seagate Barracuda 6gb
Audio: Realtek ALC 892
WiFi / Bluetooth: Broadcom bcm94331running on a PCI Express X1 Adapter
Display: Samsung U28E590 28" (3840x2160)
I'm attaching what I see on my screen after using the recommended boot args (-v nv_disable=1 slide=0 ) - two images.
I'm attaching my current config.plist file (but its virtually the same as the suggested one, I've downloaded it from https://www.elitemacx86.com/threads/guide-creating-a-basic-config-plist-file-for-booting-macos.257/ and replaced "iMac 17,11" by "iMac Pro 1,1" on both "Family" and "Product Name" values.
Could you possible help me @EliteMacx86 @Striker ? Thank you!
PS: I already have a Windows 10 installed on the same NVME drive, but it shouldn't be an issue since the EFI folder has 200mb and I have 500gb of free space on the NVME so that I can create the APFS partition.
  • config.plist.zip
    config.plist.zip
IGPU: None
This thread is only for the exact hardware. Create a separate thread. Attach your PR files.
jeklesnek
