MacOS Sequoia 15.7.5 killed Continuity on my Hackintosh
Here are the updated PR files you requested (current config.plist and fresh IOReg) after applying your previous checklist. Both validate correctly with ocvalidate.
I have also extracted a DMAR.aml under Windows using SSDTTime with VT-d enabled in BIOS, but I have not modified or added it to OpenCore yet. I will wait for your instructions on how exactly to patch and use it.
Still a couple of issues. Make the following changes:
- Enable ExtendBTFeatureFlags and Remove ProvideCurrentCpuInfo
- Kexts loading order is not correct.
- You were asked to remove the Kernel patches as you're already using a supported SMBIOS.
- agdpmod=pikera shouldn't be required for your hardware.
- RestrictEvent patching is not done correctly.
- Drivers loading order is not correct. Mandatory drivers should load first.
- Follow the VT-d implementation guide. Just a quick tip - Your DMAR table has two memory reserved region. Patch it and you should be good to go!
I have a question about my DMAR table. In the hex/decoded view I see two reserved memory regions:
– Base 0x00000000B182C000 – End 0x00000000B184BFFF – PCI Path 14,00
– Base 0x00000000B3800000 – End 0x00000000B7FFFFFF – PCI Path 02,00
You mentioned that my DMAR table has just one memory reserved region to patch. Which one exactly should I remove and which one should I keep?
Also, when I try to compile the edited DMAR.dsl with iasl 20251212 on two different Macs, iasl hangs and never finishes. Could you please compile the corrected DMAR.dsl into SSDT-DMAR.aml for AppleVTD for me?
Delete line 70-101 in the original DMAR table and then compile. Should get compiled. You still have to drop the OEM DMAR table and then inject the patched one.
I really appreciate all your help. I was not able to fully implement your advices as a whole, despite spending a few days trying. The key problem was applying the custom ACPI file generated under Windows using SSDTTime to dump the AML tables, Intel ACPI compiler iasl to decompile and compile AML/DSL, and Notepad++ for editing. No matter how many combinations I tried, either the USB disks and keyboard would stop working, or the keyboard worked but the USB disks did not. Enabling VT-d in BIOS only made things worse instead of helping. Even though I followed your guide very carefully, I still could not get the CPU to report correctly without errors. The values I had set in config.plist under PlatformInfo/Generic kept getting lost, and instead I would see data for some random MacBook, and even that was mostly empty, which in turn broke my software licensing for development tools.
However, I have still incorporated many of your suggested fixes into my config.plist. I also set the iGPU to headless mode as you recommended, and I consider that a small but meaningful success. I am not discarding our experiment; I only saved the new config.plist files under backup names and went back to my older one, with those corrections from you that did not destabilize the system. I may well return to this project later. For now, thank you for your time and assistance. I truly appreciate it, and it was definitely not time wasted, quite the opposite. Warmest greetings from Poland.
P.S. I've been using Hackintosh since right after the OS X Leopard release. I plan to stick with this one—probably my last—until it falls apart. I'm an optimist; I just transferred data from four 20-year-old HDDs to a new 2TB HDD. Adventure, keep going!
Not a problem. But in terms of VT-d, it's quite simple. Will re-cap the steps. VT-d is necessary since macOS Monterey so that native drives can be used instead of third party drivers.
1. Enable VT-d and uncheck DisableIoMapper and DisableioMapperMapping.
2. Reset NVRAM and boot to macOS. If you encounter crashing, then turn off Ethernet/WiFi.
3. Open MaciASL. File>New from ACPI and open the DMAR Table.
4. Look for the memory regions, per your previous ACPI table, you have two memory regions. The first one starts from line 70 and ends at line 84:
Similarly, the second region starts from line 87 and ends at line 101:
5. If the regions have not changed in the table, then delete line 70-101 in the original DMAR table and then click oncompile. Should get compiled.
6. Save it as SSDT-DMAR. aml and copy it to the ACPI directory of your EFI.
7. In your config.plist, add SSDT-DMAR.aml in the Add tab and drop the OEM DMAR table in the Delete tab. Then save your config.plist.
Now, you should be all good. Verify if AppleVTD is loading in IOReg.
If you encounter network related issues with Ethernet or WiFi, then enable DisableIoMapperMapping.
[edited 04/12/26] I’ve implemented all of your recommendations except for one. I wasn’t able to compile the DSL file into an ASL file — neither on Windows nor on macOS. Across many attempts, I managed to generate an ASL file only once, with the two memory regions removed according to your instructions. However, both the original ASL dump and that one successful edited ASL produced the same result: with VT‑d enabled in BIOS, USB stops working.
One more observation: with help from an AI assistant I checked the dumped ACPI tables, and in none of the disassembled outputs does the DMAR table get turned into a proper ASL source with a DefinitionBlock ("", "DMAR", 0x00000001, "INTEL ", "SKL ", 0x00000001) (or any similar DefinitionBlock for DMAR) at the top. All iasl builds I tested only produce the decoded DMAR data table (the binary/table-style listing), so I never get a clean ASL DefinitionBlock { ... } that I can edit and recompile.
I also added DMAR to the ACPI → Delete section in config.plist, and with that entry the system boots normally. Without the Delete entry, USB does not work in macOS. In the OpenCore picker USB always works.
Grok suggested removing only the final “reserved memory” block and the hex garbage. I tried that, saved the DSL, but I wasn’t able to compile DSL → ASL even once, so I couldn’t test whether that approach would work.
I’m attaching my current config.plist with SSDT‑DMAR.aml disabled, as well as the original DMAR.dsl before editing. In BIOS I currently have VT‑d enabled, and SSDT‑DMAR.aml disabled in config.plist.
Everything works, but I still can’t get the system to function properly with the AML file, as per your guidance. Is it possible that Grok’s suggestion has merit? Another AI claims it contradicts Dortania’s guidelines. Could it be that my motherboard (ASUS Prime H270‑Plus) simply doesn’t require SSDT‑DMAR.aml for OpenCore? Or is it possible that one of the other ACPI files in EFI/OC/ACPI conflicts with DMAR?
And one more question: since my attempts to compile the edited DSL into a working ASL file have consistently failed, would you be able to generate the correct ASL file on your side, based on the DMAR.dsl I’ve attached?
PS. Edited ZIP
TRUONG
