MacOS Sequoia 15.7.5 killed Continuity on my Hackintosh
Anubis111
Asus Prime H270 Plus, Macbook Pro 2019 13'
i7 6700
RX 570
15.x
  1. iMac Pro
For years I had perfectly working Continuity on my hackintosh (Asus Prime H270-Plus, SMBIOS iMacPro1,1) – iPhone as a wired camera and microphone over USB, no hacks, everything just worked in Zoom and other video apps. After updating macOS Sequoia from 15.7.4 to 15.7.5, Continuity simply died: the Mac stopped seeing the iPhone as a camera/mic, and all the usual “voodoo” (toggling Handoff, BT/Wi‑Fi, restarts, signing out and back into Apple ID) did absolutely nothing.
Worth noting: my Wi‑Fi has been working for a long time via an OCLP root patch (legacy card), and with this setup all Continuity features were fine up to 15.7.4, so this really looks more like a regression in 15.7.5 than a brand‑new config mistake on my side. I know that running Continuity over patched Wi‑Fi/BT is always a bit of a house of cards, but the fact it broke exactly on this Sequoia build is suspicious.
From what I’m seeing online, I’m not alone – 15.7.4/15.7.5 can nuke the entire continuity stack even on real Macs (camera, mirroring, clipboard, etc.), not just on hackintoshes. This really looks like a bug in this specific Sequoia build, not a misconfigured SMBIOS or missing kexts; some people report similar issues only went away after the next macOS patch rather than after the usual troubleshooting rituals.
For now I’ve completely ditched Continuity and switched to using my iPhone as a webcam via Camo/EpocCam, i.e. a classic bridge app that exposes the phone as a regular virtual UVC camera to macOS. It’s stable, but definitely a step back from the native solution that had “just worked” for years. If anyone is running a hackintosh with iMacPro1,1 and Sequoia 15.7.5 where Continuity Camera still survives after the update (especially with OCLP‑patched Wi‑Fi/BT), I’d love to see your setup and any workarounds – because right now this release just looks broken.
So, just to recap, you had 15.7.4 and upgraded to 15.7.5 and the continuity broke?
On 15.7.4 (and earlier) everything worked fine. After updating to 15.7.5 with a small iPhone communication update, Continuity between my iMac and iPhone stopped working (camera and microphone). I can still charge the iPhone over USB, see it in Finder, and import photos into the Photos app.
Did you check this on a real Mac to double check if the OS version is causing the issue?
Yes, I connected the iPhone with the same USB cable to my 13" 2019 MacBook Pro.
Everything works perfectly.
By the way, a small addition: on my iPhone 12 mini I have the latest iOS 26.4 distribution installed. On the MacBook Pro (without OCLP) I’m running the same Sequoia version as on the Hackintosh, 15.7.5.
I also tried changing the USB cable (to Hackintosh) to another one that I bought recently.
What about without cable? Does continuity work that way with your real MacBook Pro?
Connectivity works on the MBP even without a cable.
On the Hackintosh (Fenvi919 + latest OCLP it doesn’t work, and I don’t think it ever did). However, it used to work over a USB cable, and now it doesn’t.
I tested with two USB cables and with both of them the camera and microphone work fine on the MacBook Pro. On the Hackintosh, when I connect the iPhone via USB it shows up in Finder and I can import photos from it (for example into Photos), but the microphone and camera for Continuity still do not work.
Edit April 2:
Interestingly, when using the Camo Studio app on the iPhone and macOS, everything works.
Edit April 2:
This is interesting. So, this means real MacBook isn't affected but something with the non-Apple machines only.
It looks that way, I guess.
Pumpky
