Rebooting during Installation for macOS Sequoia
JTHaunter
HP Elitedesk 800 g4 35w DM
Intel Core i5 8500T
Intel UHD 630
15.x
Hi, I'm trying to install macOS Sequoia on my HP Elitedesk 800 g4 35w DM, and I am able to boot into recovery and run the installer, but at about 40 minutes ish, it reboots itself each time. I've already set SecureBootModel to Disabled, as well as set DisableSecurityPolicy to True. I'm also using a USB 2.0 and I've reset the NVRAM many times. Please help! Here's the efi and specs.
CPU: Intel Core i5 8500T
iGPU: Intel UHD 630
8GB ram
iGPU: Intel UHD 630
8GB ram
Your EFI is not as per the guide. You've injected the kexts blindly without knowing your system's specification.
Pumpky
