Dell XPS 13 i7-1065G7 Video Memory Stuck at 35MB after patchig DMVT Monterrey
i managed to set DVMT to whatever value but i still cannot get to apple logo there is always a hang on the logs before also cfg is unlocked properly with the now tool i used. I still cant get to apple logo or login screen i get stuck on logs
i managed to put it to 64MB but i still can't get to apple logo or login screen (only in vesa mode with -igfxvesa) or if i inject a device id but then vram is very low 3-35MB
Is your screen QHD/4K?
Then, 128MB might be required. It might be also possible that the EDID patching is required in your case.
i set dvmt to 128, did edid patching and get to "AppleActuatorDeviceUserClient :: start Entered" then ths screen dims a bit and the logs stop, if i press caps lock the light turns on an off so it didnt crash
i've been trying config changes but nothing i searched online seems to work
thadrumr
