Mini pc Beelink
38Nic
Asrock Z790 PG Riptide
I7 13700k
Sapphire Radeon Rx580 8Gb
15.x
  1. Mac Pro
Buongiorno,
sono a chiedere per cortesia se il mini pc in oggetto, modello EQR7, Ryzen 7 7735U, 32gb ram, Intel wi-fi 6 AX200, Radeon 6600m e' compatibile per l'installazione di Sequoia.
A disposizione per altre informazioni.
Grazie
Buongiorno,
Grazie
English only!
Good morning,
I'd like to ask if the mini PC in question, model EQR7, with Ryzen 7 7735U, 32GB RAM, Intel Wi-Fi 6 AX200, and Radeon 6600M, is compatible with Sequoia.
I'm available for further information.
Thank you.
Good morning,
Thank you.
Very Good Morning,
Should be compatible.
Could you help me create the USB? Thanks
Ok, I followed the whole procedure creating the USB stick but when I get to the attached screen after doing the NVRAM reset I click on option 1 but the PC continues to reboot
During installation, I get the following error. Can someone please help me? Thanks.
Nic
Nic
Attach EFI and BIOS settings.
aaaaaw
