Not Possible to Install on AMD R5 5600h
Victus by HP Laptop 16-e0xxx
AMD Ryzen 5 5600H with Radeon Graphics
RX 5500M(got burned due to short-circuit so currenty not available(disabled))
I was trying to install MacOS for 2 years on AMD Ryzen 5 5600h with Radeon Graphics and Graphic Card RX 5500M , 8 GB RAM, Laptop Model is HP victus 16.5' , I tried VMware , VirtualBox and Direct Install to hardware with Most Possible version like "Montery" , "High Sierra", "Catalina", "Ventura" and with OpenCore install but still , I am unable to install, 😒 I tried to create My own EFI but everytime I failed , Idk what is problem , Can anyone share their EFI for this config ? Recently I tried this EFI and I got stuck on OpenCore Bootloader. after passing loots code on screen It returns to OpenCore Bootloader without any visible error on even OpenCore LOG and screen .
Probably, there was Kernel Panic.
Provide the BIOS Settings and the boot video.
I know my plist and kext can have lots of ambiguities and mistakes but I tried my best to create an EFI by watching video, On some point I had to choose things as per my configuration and that could be the problem. Maybe. If anyone is free and wants to create EFI for my configuration then I can provide the necessary information. Your help will be appreciated😊
  • Video_2024_02_29_20_01_12.mov
    8.6 MB
Provide the new updated EFI which you created using the guide.
  • Sad
Oh I deleted all that in frustration, I have to recreate the EFI.😮‍💨
sir if you want badly to use mac os, you can use it via virtualbox, ive used monterey version on my ryzen 7 5800h igpu
Virtualbox and VMware lacks Graphics acceleration.
Dnt reply this thread
jeklesnek
