Help me please. I had a problem right after installing MacOS using the tutorial from OpenCore, I got this problem, it doesn't load into the system
AlexPogo185
MSI B550M PRO-VDH
R5 5600G
RX 570 8G
15.x
I had a problem right after installing MacOS using the tutorial from OpenCore, I got this problem, it doesn't load into the system setup (where like name of the user and all that) There will be the video with the problem.
Use Verbose and then post. Attach your EFI to check.
What macOS version are you trying to install? What's the boot disk model?
Can I enable verbose boot after the copying Mac OS install files on the disk? Trying to install Mac OS Sonoma. Disk model: WDC media 120 gb pci sata ssd (smth like this). Here is the edit folder on google drive: Efi folder in zip
I enabled verbose boot, there is the log:
00:000 00:000 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:010 00:010 AAPL: #[EB.H.IS|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:020 00:009 AAPL: #[EB|H:IS] 0
00:030 00:010 AAPL: #[EB|LOG:INIT] 2025-04-09T06:51:06
00:040 00:009 AAPL: #[EB|VERSION] <"bootbase.efi 580.140.1~51 (Official), built 2024-07-19T23:22:10-0700">
00:050 00:010 AAPL: #[EB|BUILD] <"BUILD-INFO[411]:{"DisplayName":"bootbase.efi","DisplayVersion":"580.140.1~51","RecordUuid":"5A1AECF0-94BF-4928-93FC-9CDE3C2EF371","BuildTime":"2024-07-19T23:22:10-0700","ProjectName":"efiboot","ProductName":"bootbase.efi","SourceVersion":"580.140.1","BuildVersion":"51","BuildConfiguration":"Release","BuildType":"Official","Compiler":"clang-1500.3.9.1","SdkVersion":"14.7","SdkBuild":"23G1000s","TargetArchitectures":"x86_64"}">
00:061 00:010 AAPL: #[EB.CFG.DEV|!] Err(0xE) <- RT.GV booter-strict-xmlparser 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:071 00:010 AAPL: #[EB|CFG:DEV] r5 0x0 0x0
00:081 00:010 AAPL: #[EB|H:IS] 0
00:091 00:009 AAPL: #[EB|WL:MODE] 0
00:101 00:009 AAPL: #[EB|CFG:ARG] boot-save-log 0x0000000000000002 (0x0000000000000002 < 0xFFFFFFFFFFFFFFFF) default
00:111 00:009 AAPL: #[EB|CFG:ARG] wake-save-log 0x0000000000000002 (0x0000000000000002 < 0x0000000000000002) default
00:121 00:010 AAPL: #[EB|CFG:ARG] console 0x0000000000000001 (0x0000000000000001 < 0x0000000000000001) default
00:132 00:010 AAPL: #[EB|CFG:ARG] serial 0x0000000000000001 (0x0000000000000001 < 0x0000000000000000) default
00:142 00:009 AAPL: #[EB|CFG:ARG] preoslog 0x0000000000000001 (0x0000000000000001 < 0xFFFFFFFFFFFFFFFF) default
00:152 00:009 AAPL: #[EB|CFG:ARG] timestamps 0x0000000000000000 (0x0000000000000000 < 0xFFFFFFFFFFFFFFFF) default
00:162 00:009 AAPL: #[EB|CFG:ARG] log-level 0x0000000000000001 (0x0000000000000001 & 0x0000000000000021) default
00:172 00:009 AAPL: #[EB|CFG:ARG] breakpoint 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
00:182 00:010 AAPL: #[EB|CFG:ARG] kc-read-size 0x0000000000100000 (0x0000000000100000 < 0xFFFFFFFFFFFFFFFF) default
00:192 00:010 AAPL: #[EB|CFG:ARG] force-error 0x0000000000000000 (0x0000000000000000 & 0x0000000000000000) default
00:202 00:009 AAPL: #[EB|H:IS] 0
00:212 00:010 AAPL: #[EB|WL] 0 0 0x01 0x01 0 0x00
00:222 00:009 AAPL: #[EB|BRD:NV] Mac-7BA5B2D9E42DDD94
00:232 00:010 AAPL: #[EB|B:VAw]
00:243 00:010 AAPL: #[EB|B:IAw]
00:253 00:010 AAPL: #[EB|WL] 0 0 0x01 0x01 2 0x00
00:263 00:010 AAPL: #[EB.BST.IDT|+]
00:273 00:009 AAPL: #[EB|BM] J137AP
00:284 00:011 AAPL: #[EB.BST.IDT|-]
00:294 00:009 AAPL: #[EB|WL] 0 0 0x01 0x01 3 0x00
00:305 00:010 AAPL: #[EB|WL] 0 0 0x01 0x01 4 0x00
00:315 00:010 AAPL: #[EB|BRD:NV] Mac-7BA5B2D9E42DDD94
00:325 00:010 AAPL: #[EB|WL] 0 0 0x01 0x01 5 0x00
00:335 00:009 AAPL: #[EB.H.CHK|BM] 0x0000000000000000
00:345 00:010 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:355 00:009 AAPL: #[EB|WL] 0 0 0x01 0x01 23 0x0E
00:365 00:010 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:376 00:010 AAPL: #[EB|WL] 0 0 0x01 0x01 24 0x0E
00:386 00:010 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.GV boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:396 00:010 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-signature 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:406 00:010 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image-key 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:416 00:010 AAPL: #[EB.H.LV|!] Err(0xE) <- RT.SV- boot-image 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:426 00:010 AAPL: #[EB|H:NOT]
00:437 00:010 AAPL: #[EB|SB:P] 0x1
00:447 00:010 AAPL: #[EB.B.MN|BM:+SB]
00:457 00:010 AAPL: #[EB|LIMG:DP] Acpi(PNP0A03,0)/Pci(8|2)/Pci(0|0)/SATA(1,FFFF)/HD(Part2,Sig64B8A7D8-54FB-44C5-9CA0-7F1EE510B526)/VenMedia(BE74FCF7-0B7C-49F3-9147-01F4042E6842)
00:467 00:009 AAPL: #[EB|LIMG:FP] \FA14B7C1-A416-4F26-BD01-5B1AEA3303B1\com.apple.installer\boot.efi
00:477 00:009 AAPL: #[EB|LIMG:OPT]
00:487 00:010 AAPL: #[EB.OPT.LXF|F] <"\\FA14B7C1-A416-4F26-BD01-5B1AEA3303B1\\com.apple.installer\\com.apple.Boot.plist">
00:498 00:010 AAPL: #[EB.LD.LF|IN] 0 1 <"\\FA14B7C1-A416-4F26-BD01-5B1AEA3303B1\\com.apple.installer\\com.apple.Boot.plist"> <"0">
00:508 00:010 AAPL: #[EB|KF] <"-no_panic_dialog -restore -logOnCrash -rootdmg-ramdisk auth-root-dmg=file:///com.apple.installer/x86_64SURamDisk.dmg">
00:518 00:009 AAPL: #[EB|MBA:CL] <"">
00:528 00:010 AAPL: #[EB|MBA:NV] <"-v keepsyms=1 debug=0x100 agdpmod=pikera slide=192">
00:538 00:010 AAPL: #[EB|MBA:KF] <"-no_panic_dialog -restore -logOnCrash -rootdmg-ramdisk auth-root-dmg=file:///com.apple.installer/x86_64SURamDisk.dmg">
00:549 00:010 AAPL: #[EB|MBA:OUT] <"-v keepsyms=1 debug=0x100 agdpmod=pikera slide=192 -no_panic_dialog -restore -logOnCrash -rootdmg-ramdisk auth-root-dmg=file:///com.apple.installer/x86_64SURamDisk.dmg">
00:559 00:010 AAPL: #[EB|LOG:VERBOSE] 2025-04-09T06:51:06
00:569 00:009 AAPL: #[EB.CSR.S|VAR] 0x00000040
00:579 00:009 AAPL: #[EB|OPT:BM] 0x280182
00:589 00:010 AAPL: #[EB.OPT.LXF|F] <"\\FA14B7C1-A416-4F26-BD01-5B1AEA3303B1\\com.apple.installer\\PlatformSupport.plist">
00:599 00:010 AAPL: #[EB.LD.LF|IN] 0 1 <"\\FA14B7C1-A416-4F26-BD01-5B1AEA3303B1\\com.apple.installer\\PlatformSupport.plist"> <"0">
00:611 00:011 AAPL: #[EB.OPT.RKS|!] Err(0xE) <- BS.LocP EDB4A040-6D8A-11EC-8FAD-3E22FB93ADCF
00:621 00:010 AAPL: #[EB|KMR] 373219328
00:631 00:009 AAPL: #[EB.CS.CSKSD|+]
00:641 00:010 AAPL: #[EB.CS.CSKSD|!] Err(0xE) <- RT.GV boot-info-payload 8D63D4FE-BD3C-4AAD-881D-86FD974BC1DF
00:651 00:009 AAPL: #[EB|WL] 0 0 0x01 0x01 6 0x0E
00:661 00:010 AAPL: #[EB.CS.LFC|+]
00:671 00:010 AAPL: #[EB.LD.LF|IN] 0 1 <"System\\Library\\Caches\\com.apple.corestorage\\EncryptedRoot.plist.wipekey"> <"0">
00:683 00:011 AAPL: #[EB.FS.AGSVH|RU] FA14B7C1-A416-4F26-BD01-5B1AEA3303B1
00:693 00:009 AAPL: #[EB.FS.AGSVH|!] Err(0xE) <- BS.LocHB 59D76AE4-37E3-55A7-B460-EF13D46E6020
00:703 00:010 AAPL: #[EB.G.CS|-?] Ok(0)
00:722 00:019 AAPL: #[EB.LD.LF|IN] 0 1 <"<null string>"> <"1">
00:736 00:014 AAPL: #[EB.B.SBS|SZ] 723512
00:755 00:018 AAPL: #[EB|B:SHA] <d10086da43a5980e1396591cc365311442386d76>
00:772 00:016 AAPL: #[EB.WL.PWLFNV|!] Err(0xE) <- RT.GV wake-failure 7C436110-AB2A-4BBB-A880-FE41995C9F82
00:785 00:012 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFNV
00:796 00:011 AAPL: #[EB.WL.PWLFRTC|NONE]
01:543 00:746 AAPL: #[EB.WL.DT|!] Err(0xE) <- EB.WL.PWLFRTC
04:990 03:446 AAPL: #[EB.FS.AGSVH|RU] FA14B7C1-A416-4F26-BD01-5B1AEA3303B1
05:005 00:015 AAPL: #[EB.FS.AGSVH|!] Ok(0) <- BS.LocHB 964E5B22-6459-11D2-8E39-00A0C969723B
05:017 00:012 AAPL: #[EB.FS.AGSVH|GVI!] Err(0x3) 0
05:030 00:012 AAPL: #[EB.FS.AGSVH|GVI!] Err(0x3) 1
05:116 00:086 AAPL: #[EB.FS.AGSVH|GVI!] Err(0x3) 2
05:129 00:013 AAPL: #[EB.FS.AGSVH|GVI!] Err(0x3) 3
05:142 00:013 AAPL: #[EB.FS.AGSVH|GVI!] Err(0x3) 4
05:157 00:014 AAPL: #[EB|FMUFSV] RV FA14B7C1-A416-4F26-BD01-5B1AEA3303B1 0x00000040
05:172 00:015 AAPL: #[EB.LD.LKC|CFG] <"\\com.apple.installer\\BootKernelExtensions.kc">
05:188 00:015 AAPL: #[EB.LD.LF|IN] 0 1 <"\\com.apple.installer\\BootKernelExtensions.kc"> <"0">
06:149 00:961 AAPL: #[EB|SB:P] 0x1
06:163 00:013 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
06:178 00:015 AAPL: #[EB|SB:MF] \\com.apple.installer\\BootKernelExtensions.kc.j137ap.im4m
06:195 00:016 AAPL: #[EB.LD.LF|IN] 0 1 <"\\com.apple.installer\\BootKernelExtensions.kc.j137ap.im4m"> <"0">
06:357 00:161 AAPL: #[EB|SB:MKRN]
06:374 00:017 AAPL: #[EB.LD.LKFS|-?] Ok(0)
06:385 00:011 AAPL: #[EB.LD.LKC|-?] Ok(0)
06:400 00:014 AAPL: #[EB|BST:REV1]
06:411 00:011 AAPL: #[EB|CSR:OUT] 0x00000040
06:423 00:011 AAPL: #[EB.BST.FBS|+]
06:434 00:011 AAPL: #[EB.BST.FBS|ADSZ] 0
06:446 00:011 AAPL: #[EB.BST.FBS|KSSZ] 0
06:458 00:012 AAPL: #[EB|SB:SBGMFNS] j137ap.im4m
06:472 00:014 AAPL: #[EB|RH:PF] usr\standalone\OS.dmg.root_hash
06:487 00:014 AAPL: #[EB|RH:MF] <"usr\\standalone\\OS.dmg.root_hash.j137ap.im4m">
06:501 00:014 AAPL: #[EB.LD.LF|IN] 0 1 <"usr\\standalone\\OS.dmg.root_hash"> <"0">
06:516 00:015 AAPL: #[EB.LD.OFS|OPEN!] Err(0xE) <"usr\\standalone\\OS.dmg.root_hash">
06:529 00:012 AAPL: #[EB.RH.LRH|P!] Err(0xE) <- EB.LD.LF
06:542 00:012 AAPL: #[EB.BST.FBS|!] Err(0xE) <- EB.RH.LRH
06:555 00:013 AAPL: #[EB|LOG:DT] 2025-04-09T06:51:12
06:569 00:013 AAPL: #[EB|LOG:EXITBS:START] 2025-04-09T06:51:12
Allow access to the EFI.
sabbianera
