No iam not using a certified cable just normal HDMI cable
Do you have any other Mac to test this cable? Several Cables that work on Windows, may not work
ASUS TUF B560M-E
Add the following Device properties keys and values:
AAPL,ig-platform-id: 07009B3E
enable-hdmi-dividers-fix: 01000000
enable-hdmi20: 01000000
enable-max-pixel-clock-override: 01000000
framebuffer-con0-busid: 04000000
framebuffer-con0-enable: 01000000
framebuffer-con0-pipe: 12000000
framebuffer-con0-type: 00080000
framebuffer-con1-busid: 00000000
framebuffer-con1-enable: 01000000
framebuffer-con1-pipe: 12000000
framebuffer-con1-type: 00080000
framebuffer-fbmem: 00009000
framebuffer-patch-enable: 01000000
hda-gfx: onboard-1 | STRING
Also, add agdpmod=vit9696 and igfxonln=1 in boot args. In addition, set the DVMT as 64MB in BIOS.
Save the config.plist and attach it here to check.
Here! (Sorry for late reply) (still black screen/No signal)
ryusuke17
