Message on boot saying start work loop initialise service still waiting for root device
treyant
TRIGKEY Speed S5 5800H Mini PC
AMD Ryzen 7 5800H
Radeon Graphics 8 Core 2000MHz
15.x
  3. Windows Phone
HI there,
I'm totally new to this, and been playing around for the last couple of days and got as far as boot working with the error message above, or it just loops. I've tried USB3 and USB2 with no luck. Any ideas please?!
HI there,
Attach your EFI you're using to boot!
I can't - says it's too large for the server to process. (27.2MB)
Make the following changes to your configuration:
- Remove SSDT-EC, SSDT-USBX.
- Disable ResetLogoStatus
- Disable FixupAppleEfiImages
- Kexts sorted order is not correct. Mandatory kexts should load first.
- MacPro7,1 is a poor choice. Use MacBookPro16,3.
- Add GenericUSBXHCI (AMD fork). You can grab it from the downloads.
Screen Shot 2025-03-08 at 9.42.43 pm.png Screen Shot 2025-03-08 at 9.54.15 pm.png
That's what I currently have. If this is not correct, then what changes need to be made? I'm trying to boot Sequoia
ruffles
