SOLVED my Ventura don't works anymore (SOLVED)
kaoz
ASUS TUF Gaming Z690-PLUS WiFi D4
Alder Lake i7-12700KF
AMD RX 580
  1. Mac Pro
after months i didn't use my monterey (that was working perfect) now after the boot in 10 sec i got black screen and my pc boot again..
i didn't change anything so dunno why now don't works...
what i can do?
thanks
what i can do?
thanks
Has your BIOS settings reset? Or maybe you tried to install some extension or apps which caused the issue. Maybe the SSD has some corruption issue. Post the verbose output to check.
how i said .. i didn't changes anything i didn't booth since 6 months.. and now i have this issue..
how can post the verbose.. so i do now..
Just boot and record a video and post it here.
ah ok let me to do...
I hope this is enough
The video isn't clear. It seems to be stuck. Probably, the WiFi/GPU issue. By any chance, did you update the macOS?
oh anyway i didn't rember that is Ventura not monteray haha sorry for this .. anyway i didn't update since 6 months i guess maybe more..
i never had issue with my gpu and wifi. i will try to make a more clear video.. or what i could do? don't exist the log? so maybe could be more clear for you..
Send a clear video.
raymondleung416
