Stuck at "start::512:successfully initialized ahci controller"
RohanGajjar23
Asus A17
AMD R7 6800H
AMD APU and RTX 3060
12.x
  2. Clover (Legacy)
  3. OpenCore (UEFI)
  4. OpenCore (Legacy)
  2. MacBook Air
  3. MacBook Pro
I already had hackintosh installed on my same build
OLD SPECS
CPU : I5 2400S
GPU : RX 570 4GB
MOTHERBOARD : Intel Desktop Mobo
its was working perfectly fine i was using ventura now i had to upgrade the cpu from 2nd gen to 8th gen i5 8400 and gigabyte h310m mobo and all things same
i again followed the guide and made the efi but i am always getting the
what should i do here is the efi folder
please help me out​
OLD SPECS
CPU : I5 2400S
GPU : RX 570 4GB
start::512:successfully initialized ahci controller​
what should i do here is the efi folder​
please help me out​
How come all things are same when you upgraded the Motherboard and CPU in the first place?
You'll have to adjust the Quirks for the new hardware
like the Ram, sata ssd, gpu (rx 570) are same just upgraded the mobo and cpu but still getting stuck at ahci controller power state something i created the efi from scratch following the guide
NEW Specs
CPU : i5 8400
RAM : 16GB 2666mhz
MOBO : Gigabyte h310m DS2
GPU : RX 570 4gb
and also in bios i had secure boot to false csm to false etc from the guide
NEW Specs
CPU : i5 8400
RAM : 16GB 2666mhz
GPU : RX 570 4gb
The Network kext is missing.
Why are you using AppleALCU? H310 does not have USB Audio.
Also, did you disable the IGPU?
Okay so can you please share me the guide ? cause i changed everything the error goes down to ahci controller can you please explain me a little bit about it?
again same error even after following the guide same error for the stuck at successfully initalized ahci controller can you please help me?
you there ? can you please help me?
Disable IGPU first from the BIOS.
alvarg82
