Hi, what do you think will work this configuration?
Laptop/Motherboard: Asus FA507NV
CPU: Ryzen 7 7735HS
Graphics: AMD Radeon 680M | RTX 4060 Laptop
RAM: 16GB(8x2) DDR5-4800 hynix HMCG66MEBSA095N
SSD: ADATA SX8200Pro | Micron_2400_MTFDKBA512QFM
CPU: Ryzen 7 7735HS
Hello,
You can install it but the APU will not have the acceleration.
Hello, what do you think will work in this configuration?
Motherboard - Processor
ASUS P8H67-V i5 2400 hd 3000
- DDR3 16gb RAM
- Geforce gtx 970
- DDR3 16gb RAM
- Geforce gtx 970
High Sierra
- DDR3 16gb RAM
- Geforce gtx 970
High Sierra will have native support. Else, you can use higher version and patch the IGPU as NVIDIA drivers are still experimental.
ebillah
