when I use many tasks, the device lags, it becomes unusable. The device must be turned off by the power button.
No problem reporting files attached.
This is my report file. Everything seems to work very well except for the use of many tasks it crashes. Thank you for your help!
It's an incomplete PR file. Please attach your complete PR files.
How to get "Problem Reporting files"? Sorry for that. I am a newbie!
No kextcache output attached.
The ACPI is not patched properly. It must be saved as .aml extension to read. Follow the guide here: https://www.elitemacx86.com/threads/guide-how-to-patch-laptop-dsdt-and-ssdts.178/
NullCPUPowerManagement must be removed.
Update WEG+Lilu and the other kexts.
Remove the kexts related to HD 3000. Install the package with the appropriate selection. Rebuild the cache. Restart and reply with new files. If possible, provide the screenshots for the package you install.
Dear,
sorry for my late reply!
I found out that if I connect a TV or monitor on the HDMI port both monitors show up (the internal Display and the TV / Monitor)
If I disconnect HDMI cable from the 2. monitor or TV the internal display also turns black
The driver seems to work because the complete VRAM is availible and show up in systeminformations
I think there are some Graphic issues and made a screenshot of it
I saved the IOReg after I installed the driver
Dear,
The DSDT is still not fully patched. Several patches are missing.
No backlight implementation.
No Audio Injection.
Here are few things you need to do.
1. Update the system to 10.14.6. Make sure to read instructions for the HD 3000 fix as it will result in black screen after installing. If you've done several experiments, i suggest you to install 10.14.6 with a invalid ig-platform-id.
2. Once you boot, install the clover and rest things. Make sure to update the Clover and the drivers. Fix the Graphics using the installer method guide.
3. Restart and extract the DSDT and SSDT. Make sure you apply the HD 3000 High Resolution fix.
4. Apply the rest of the patches to the DSDT.
5. Restart and check. Attach new PR files.
hj everyone, I am a newbie hackintosh
please help me fix problem with hd grapphice 3000 hackintosh mojave 10.14.1
Vram just get only 3mb, so can adjust resolution to 1366x768
can my hackintost get full resolution with mojave 10.14.1
No PR files attached. Read here:
Laptop: Samsung np300e4z-s06vn
CPU: Intel Core i3-2350M/HM65
Graphics: Intel HD Graphics 3000, 1366x768
Bootloader: Clover(UEFI)
can my hackintosh get full resolution?
  • CLOVER.zip
    CLOVER.zip
kaikkmi
