GUIDE How to Enable NVIDIA Graphics on macOS [Clover/OpenCore]
I haven't installed it yet but i did something else. I disabled the free synch option and set my refresh rate at 60Hz fixed. It stopped flickering. But still can not use both the monitor at the same time. Is there any way i can increase the system to support high res high refresh. Guess if i can enable that i might be able to use dual monitor.
Does the system have Graphics acceleration? Provide a picture of the Desktop (with Dock and About This Mac).
i think it has acceleration.
Yes, so it seems like there is a proper acceleration as the Dock is transparent now.
What display connection are you using for the current monitor?
HDMI only
not pluged in at the moment also HDMI. Don't have any DP.
Try to connect and then check if you get the display on both monitors.
no i tried dual monitor final stage all black. only single monitor works. Seems like it is not supporting more then 60Hz.
Set it to 30Hz and then check.
19_triage.sheaves
