Seeking help to solve GPU HEVC encoding issue on Hackintosh system
onesbug
ASUS
Intel Xeon Processor/Intel Core i9 13900K
RX580/RX5700
  1. Mac Pro
Hello everyone, can anyone help me solve the problem of using GPU for HEVC encoding on a Hackintosh system? I have two computers, both of which have been correctly installed with Hackintosh and enabled graphics cards. VideoProc shows that both h264 and HEVC are activated, but neither of them can enable HEVC when using Parsec. When testing with transcoding software, it seems to use ffmpeg's CPU decoding instead. The CPU of my first computer is Intel Xeon W and the graphics card is RX5700. The CPU of my second computer is Intel Core i9-13900k and the graphics card is RX580.
No PR Files attached.
Thanks for your reply.I'm interested in knowing how to fully utilize HEVC encoding on my Hackintosh, rather than just having VideoProc show that it's "activated."
Sometimes, you need to create a custom profile to utilize HEVC.
I am a Parsec user too, but never found a solution.
@onesbug did you found a solution?
I have the same problem.
Thank you very much.
Dzikon
