Wifi/Bt Dongle Buying Advice (Mac Os 15.2)
mcleon
hp laptop 15s-eq2xxx
AMD Ryzen 5500u
AMD Raedeon Graphics
15.x
I need a wifi and bluetooth dongle best for me would be a 2 in1.
I dont have much knowledge but i could install kects without a problem.
Main mission for me would be to get Airplay working.
(Sorry for my spelling mistakes im German.)
Thanks in advance :)
Is this for a Laptop or Desktop?
For a Laptop i got a wifi dongle probably.A 2 in 1 dongle would be the best for me but the only one i need would be a bluetooth dongle now to get airplay working right?
AirPlay has several requirements. Why not replace the internal WiFi/BT card to have more seamless function?
its a laptop thats like only 4 month old and has guarantee so i probaly wont do it.
i bought a tlink archer t2u v3 and a asus bt400 dongle will they work with airplay ?
wifi works and im exspecting to get the bluetooth dongle on monday wifi works with the big sur adapter software
but if it isnt possible with that configuration it would be nice if you gave me some advice for wifi cards that i could use
ASUS BT400 works fine. TP-Link Archer doesn't seem to be native chipset but more likely Mediatek/Realtek.
You can follow the BT guide on the forum!
what is a native chipset wifi dongle that is compatible with airplay and airdrop then?
perfect for me would be something that i can buy in germany amazon would also be fine i guess.
Thanks again
PixelNyan
