No display on DP but on VGA works Intel IGPU 530
thatalexfr
Lenovo M700 Tiny
I5 6400T
Intel IGPU 530
15.x
Hello so I am trying to setup my Lenovo m700 Tiny (i5 6400t Intel HD 530) on Sequoia but I installed the whole os on the VGA port all fine with no problems and I have graphics working (apart for the fact the color profile for my monitor is over contrasted) but I tried to ON THE SAME DISPLAY use DP and not VGA but when I power on my PC I see the Opencore loader then the verbose and when its supposed to exist verbose and show me the apple logo and loading and then Lock Screen my screen turns off and if I plug in VGA then unplug and replug in then VGA works
Thanks for any help
Thanks for any help
Set DVMT to 64MB and remove fbmem and stolenmem entry and consider using OCLP for using the SKL framebuffer.
Similar threads
chrisgamessss
