macOS Big Sur and Atheros QCWB335 wifi
Kernel
Dell G15 5510
Intel Core i7-10870H
Intel UHD Graphics 630
Hello!
I have an Atheros QCWB335 Wifi and Bluetooth chip in my computer, and Wifi is not working. Can someone help me?
Hello!
It doesn't work. Installed, but nothing happend. Wifi still not working. (My profile says macOS version 11.0 (Beta), but it's 11.0.1 (not Beta))
Is unsupported and may not work.
Can I create my own kext for, it or can I use a FakeID, or request a kext for it anywhere?
Making a kext is involves tons of work and you need couple of developers. The best possible solution is to replace your card with a compatible one.
What is the best and cheapest and fully supported for macos big sur?
A WIP list is here:
Is a sierra wireless em7455 qualcomm snapdragon x7 lte-a supported?
I found some files for it on the internet, but it crashes my computer. I think I'll buy an USB WiFi Adapter.
hapaya666
