Kernel Panic on OC Big Sur 11.3
BigSur_Ghana
Coffee Lake
i5 8265U
Intel UHD 620
10.13.x
  2. OpenCore (UEFI)
Hi. I have a Lenovo s540 i58265U, Coffee Lake, ALC257 machine. I am trying to install Big Sur from 2 months but not able to get their. Today I used a prebuilt EFI and modified the SMBIOS and graphics settings and Boom...
My USB just booted up... But getting this error after installation reaches the last stage of installation. The Kernel panics then with following errors(Photo 2). Please tell me how to resolve this error.
Thanks.
Thanks.
Never use someone's else EFI. Update VirtualSMC.kext.
Sure Sir....
But I was totally depressed and Frustrated 😸🧐😤
You should consider following the guide and then create a EFI for your exact hardware.
I tried making my own EFI for 10-12 times, but always got Kernel panics or some other errors.... I updated my VirtualSMC but getting the same error.
In such case, you should attach the EFI you're using.
Rhinso
