GUIDE Internet Recovery for macOS Big Sur using OpenCore
DSM2
EVGA SR-3 DARK
Intel Xeon W-3275M
2x AMD Radeon 6900XT
12.0.x
  1. OpenCore
  1. iMac Pro
  2. Mac Pro
  3. Mac mini
  4. MacBook Pro
This guide covers Internet recovery for macOS Big Sur using OpenCore
Since Apple has not yet stored the Recovery Installer on the server, it cannot be downloaded via BDU,
I sat down and created an Internet Recovery Installer.
The Recovery Installer is a good start for Windows users and saves them a lot of work and time.
To use it you need internet access and an already configured EFI for the hackintosh.
How To
What is required ?
1) USB stick with 16 GB memory
2) Recovery Image : https://dumpich.net/nextcloud/index.php/s/7LNpdLtXncbKY5e
3) Etcher for image recovery via macOS : https://github.com/balena-io/e.../balenaEtcher-1.5.110.dmg.../balenaEtcher-1.5.110.dmg
Etcher for image recovery via Windows : https://github.com/balena-io/e...cher-Portable-1.5.109.exe...cher-Portable-1.5.109.exe
macOS User:
Windows User:
Afterwards you can store the boot and OC folder in the EFI folder of the stick and the installation can start.
Make sure that you have configured your network correctly, otherwise you can't perform an installation.​
alexcorpse
