SOLVED Installation never finishes (I'm using the same perfectly good EFI as Ventura)
pietronizzardi
MSI B450 GAMING PLUS MAX
Ryzen 5 3400G
Radeon Vega 11
  2. OpenCore (UEFI)
  1. iMac Pro
Hi, I'm installing MacOs Sonoma but the installation never finishes, the EFI is the same one I used for Ventura, which is fully functional, so it should work, but instead I can't finish the installation, I'm attaching the EFI and the verbose video. Please help me. Thank you
CPU: AMD Ryzen 5 3400G
RAM: 16GB 3200Mhz
MOTHERBOARD: MSI B450 Gaming Plus Max
View attachment VID_20240705_173155 (1).mov
EDIT:
I solved it, to install Sonoma you need to deactivate SecureBootModel
RAM: 16GB 3200Mhz
EDIT:
Glad you got it fixed.
Closing the thread!
zuikov.p
