i9-9900k, GIGABYTE Z390M Gaming, RX Vega 64 Help
ravz864
Gigabyte H110m-s2
igpu
10.13.x
need help configuring efi
9900k,
z390m gaming,
vega 64
Your profile already reflects the hardware details. No need to mention in the post. In the profile, it's indicated you're running 10.15 Beta and the thread is created in Mojave and the detail you mentioned is 10.14.6.
Please fix your profile as per FAQ.
Reactions: ravz864
Sorry my bad...I didn't.notice it...
here`s my EFI kindly see whats wrong
You did not followed the FAQ. You must omit your themes folder.
This is an incomplete PR files. No kextcache output attached. Attach your kextcache output.
pc didnt boot... after the kernel panic..(google chrome was froezen.. after restart it didnt boot) so i formatted the drive... this is the Efi i used to install kindly see if its correct ....
tiffadave
