GUIDE How to Generate SSDT for CPU Power Management
GIGABYTE Z370 AROUS GAMING 3
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
Piker-Alpha has developed a script called ssdtPRGen which will generate a SSDT for your CPU. By implementing the CPU power management, you would be able to achieve the maximum amount of power states for your CPU. Please note that CPU power management is not mandatory for Desktop CPU.
Before you start, make sure you're having a working internet connection.
Generating a SSDT for CPU Power Management
1. Before you generate a SSDT for your CPU, make sure that the correct SMBIOS has been configured for your current CPU. You can generate a SMBIOS using Clover Configurator. For more information, follow the guide here.
2. Open Terminal and download the Piker Alpha's script.
curl -o ~/ssdtPRGen.sh https://raw.githubusercontent.com/Piker-Alpha/ssdtPRGen.sh/master/ssdtPRGen.sh
For newer CPUs, use beta branch.
curl -o ~/ssdtPRGen.sh https://raw.githubusercontent.com/Piker-Alpha/ssdtPRGen.sh/Beta/ssdtPRGen.sh
3. This will download the ssdtPRGen.sh script to your user directory. The next step is to change the file permission
chmod +x ~/ssdtPRGen.sh
4. For default SSDT generation, type:
sudo ~/ssdtPRGen.sh
5. Confirm y or n and it will generate the SSDT.
6. Open Finder and in menubar and click on Go to Folder
7. Type ~/Library/ssdtPRGen/
8. Now mount your EFI partition of your system drive. For more information, follow the guide here.
9. Copy ssdt.aml to /Volumes/EFI/EFI/Clover/ACPI/patched/
  • The Power Management SSDT should always be named as SSDT.aml. If you're already having a SSDT.aml in the directory, rename it to SSDT-1.aml, SSDT-2.aml and so on.
  • The default generated SSDT is ssdt.aml. You can rename it to SSDT.aml without any issue.
10. Restart your system
Testing Power Management
After restarting, you can test the power management. To test the power management, you need to use AppleIntelInfo.kext. You can either compile AppleIntelInfo.kext using XCode or can download from the post in the attachment.
1. Download and extract AppleIntelInfo.kext to your Desktop
2. Open Terminal
3. Type:
sudo kextutil /Users/your user name/Desktop/AppleIntelInfo.kext
When promoted, enter your password.
Note:
If you get a error while loading kext, follow the steps below.
sudo chown -R root:wheel ~/Desktop/AppleIntelInfo.kext
sudo chmod -R 755 ~/Desktop/AppleIntelInfo.kext
Continue from the step 3.
4. Type:
sudo cat /tmp/AppleIntelInfo.dat
5. The power states will be shown in the Terminal .
Credits :
Pike R. Alpha
mark
Asus ZenBook UX430UNR
i7-8550u
Intel UHD 620 / Nvidia MX150
10.15.x
Clover (UEFI)
MacBook Pro
iOS
Hello guys, i have some error
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
Hello guys, i have some errorView attachment 1423
As per your profile, you should follow the Laptop Power Management guide. You do not need to generate a SSDT for your Laptop. It's not needed. Your profile needs to be fixed. Intel Core i7-8550U has Intel UHD Graphics 620 not HD 620.
Provide PR files.
mark
i7-8550u
10.15.x
Clover (UEFI)
MacBook Pro
iOS
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
streak
meenu2510
i7 3700
HD4000
Clover (UEFI)
iMac
Android, iOS
Thanks for the guide ,need to copy only SSDT.aml to Patched folder or all SSDT-1,SSDT-2,SSDT-3,SSDT-4 aml patches
CPU Ratio Info:
CPU Low Frequency Mode.............: 1600 MHz
CPU Maximum non-Turbo Frequency....: 3400 MHz
CPU Maximum Turbo Frequency........: 3900 MHz
IGPU Info:
IGPU Current Frequency.............: 350 MHz
IGPU Minimum Frequency.............: 350 MHz
IGPU Maximum Non-Turbo Frequency...: 650 MHz
IGPU Maximum Turbo Frequency.......: 1150 MHz
IGPU Maximum limit.................: No Limit
CPU P-States [ (16) 29 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 29 32 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 29 32 34 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 29 32 33 34 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 24 29 32 33 34 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 24 29 31 32 33 34 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 22 24 29 31 32 33 34 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 22 24 29 30 31 32 33 34 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 22 24 28 29 30 31 32 33 34 37 ] iGPU P-States [ (7) ]
CPU P-States [ (16) 22 24 28 29 30 31 32 33 34 35 37 ] iGPU P-States [ (7) ]
mooseknuckleboi
Asus X299 Deluxe II
i9-10980XE
AMD Radeon 5700XT Founders Edition
10.15.x
OpenCore
iMac, MacBook Pro
iOS
I've been trying to overclock my Hackintosh, but I keep running into a problem. My Hackintosh runs at 3.0 Ghz (i9 10980XE), however, when I overclock in BIOS, even to just 3.1 Ghz, the Mac will not boot. I know it is something I am missing, because windows boots fine and is stable with the overclock up to 4.1 Ghz. Is there an entry in config.plist which I'm missing? Do I truly need this SSDT to work in tandem with the already set BIOS settings for Mac OS to boot (on an overclock?) Mac already boots great without overclock, only thing not working is thunderbolt 3 HotPlug even though I followed your guide :/
The computer hangs right at boot, at the
[EB|'B:WFDW] Err(0xE), 0 @ LocHB 71B4903C-14EC-42C4-BDC6-CE1449930E49
strangely, this text all appears without the overclock applied as well, it just goes away quickly. Applied the attached energy management DDST with no effect.
System Specs:
Asus X299 Deluxe II
Arctic 208 Water Cooled CPU
i9-10980XE 18/36
Radeon RX 5700 XT
1000W 80+ Gold Phanteks PSU
OS X 10.15.7
I don't want to waste your time with too much back and forth. Is there a way to do a quick Skype/facetime or something similar? I would pay you for your time, it would be faster for both of us, and I'd write out the solution here once we are done, to help others, if you choose that. I also have a problem with TB3 HotPlug, unfortunately in all 14 pages of the HotPlug thread guide none of the answers resolved the integrated thunderbolt question with the Asus x299 Deluxe II. Thank you for your work.
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
System Specs:
Asus X299 Deluxe II
i9-10980XE 18/36
Radeon RX 5700 XT
OS X 10.15.7
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
CPU Ratio Info:
IGPU Info:
There should be more P-States. Check your work.
