GUIDE How to Enable ThunderBolt 3 Hotplug
Ferz
Gigabyte z370 AORUS Gaming 7
Intel Core i7-8700K
AORUS Radeon RX570 4GB
11.0.x
OpenCore
MacBook Air
iOS
attach my z370 ACPI file
GIGABYTE Z370 AROUS GAMING 3
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
Hello! I Have Big Sur 11.0.1 Final and OpenCore 0.6.3.
1. I've added SSDT-PLUG.aml and custom for Z370 (_SB_.PCI0.RP21 slot 4 path) SSDT-Z370-TB3HP.aml to folder OC/ACPI
2. After that I've added TbtForcePower.efi (to folder OC/Drivers)
3. put strings in config.plist for thunderbolt works (UEFI->Drivers->TbtForcePower.efi), (ACPI->Add->Two AML files).
If I add ThunderboltReset.kext to Kexts folder and add string in Kernel->Add, my Mac don't startup,
without it - after 2 minutes SSD TB disk Samsung X5 autoejects and doesn't work. what I can to do with this? Thanks
No PR files attached.
peewe
gigabyte z390 gaming sli
i7 9700
nvidia gt740
10.15.x
Clover (UEFI)
iMac
Android
Hello there,
First of all, thanx a lot for your fantastic guide.
I followed every point you described in the guide. Now my Universal Apollo 8 Works well.
i Ask you two things:
1. At boot i receive from bios boot: Failed to write GPIO - invalid parameter
Error: Invalid Parameter return from TbtForcePower.eif
2. If i got to system info/Thunderbolt. I don't see Gigabyte and the port speed is 20Gbp/s
I saw is possible to patch it and see Apple Inc. and have 40Gbp/s
Can You help me.
Thanx a lot.
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
That's nice.
That's normal.
It's already explained in the post. If you want them to show, you'll need to flash the TB chip.
Ferz
Intel Core i7-8700K
11.0.x
OpenCore
MacBook Air
iOS
could you help me or write manual to OC users please
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
Ferz
Intel Core i7-8700K
11.0.x
OpenCore
MacBook Air
iOS
if I used ssd-tb3.aml from first post with RP21 strings (I have RP21@1B,4 via IOReg), after system startup - Thunderbolt external drive works only 30 seconds and after autoejects, without aml file thunderbolt external drive works normally except hot swap and sleep mode. What I need to do? if I install and inject thunderboltreset kext, system will not startup and freezes at start...
Intel Core i9 9900K
11.0.x
OpenCore
MacBook Pro
Android, iOS
