- 11.0.x
- OpenCore
How to Enable NVRAM in Clover and OpenCore.
NVRAM is an important part of any computer system. The NVRAM stores several data such as Brightness levels even when the computer is turned off.
Since introduction of Coffee Lake CPUs, the NVRAM is missing. Following is the guide to fix NVRAM on your system.
Here is a list of system which needs NVRAM
Download
SSDT-PMC
Clover
If you're using clover, you can add the SSDT-PMC in EFI/CLOVER/ACPI/patched.
OpenCore
If you're using OpenCore, you can add the SSDT-OM in EFI/OC/ACPI
Add a link to the SSDT-PMC in ACPI section of your config.plist
Download
SSDT-PMC
Clover
OpenCore
