11.0.x
  1. OpenCore
How to Enable Intel Bluetooth on macOS [Clover/OpenCore]
An EliteMacx86 Exclusive Guide - This guide covers the implementation of Intel Bluetooth on macOS using Clover and OpenCore. By following this guide, you'll be able to enable Bluetooth on macOS using Clover or OpenCore Bootloader.
There are several Intel WiFi cards where the Bluetooth function work OOTB. However, it lacks an on and off function and can have an invalid or no Address on some systems. You'll need to use Injector which enables on and off function and the firmware upload to fix potential issues and provide full support for the Bluetooth hardware.
To enable Intel WiFi, refer to the guide linked below.
Compatibility
Not all Intel Bluetooth hardware is compatible with macOS. Refer to the thread linked below for more information on Intel Bluetooth compatibility.
WiFi/BT HardwareCompatible Intel WiFi/BT
Network KextsOriginal Network kexts in S/L/E
macOS VersionmacOS High Sierra and Later
STEP 1: Add Required Kext
To enable Bluetooth support, you'll need to add Intel Bluetooth kexts.
KextsNotes
IntelBluetoothFirmware*
  • Enables Intel Bluetooth.
  • Enables Firmware Upload to Bluetooth Device.
  • Required for all compatible Intel Bluetooth
  • For macOS Monterey, v1.1.3 or later is required.
IntelBluetoothInjector
  • Bluetooth Injector for Intel
  • Up to macOS Big Sur
  • This kext requires IntelBluetoothFirmware.kext to function.
BlueToolFixup
  • Required for Broadcom and Intel Bluetooth
  • For macOS 12 (Monterey) and Later
  • Do not use it with BrcmBluetoothInjector.kext and IntelBluetoothInjector.kext
1. Download the kexts according to your macOS version from the downloads section of this forum.
For Clover:
If you're using Clover, copy the kexts to EFI/Clover/Kext/Others
For OpenCore:
If you're using OpenCore, copy the kexts to EFI/OC/Kexts. You'll also need to add the kext entries in the Kernel section of your config.plist.
  • *Indicates mandatory kexts.
  • BlueToolFixup can be obtained from BrcmPatchRAM.zip from Acidanthera.
STEP 2: Restart your System
You can see a Bluetooth icon in the menu bar now. If not, you can enable it from System Preferences>Bluetooth>Show Bluetooth in the menu bar.
mrlock89
