11.0.x
  1. OpenCore
How to Enable AMD RX 6800, RX 6800XT and RX 6900XT Graphics on macOS Big Sur
An EliteMacx86 Exclusive Guide - This guide covers implementation of AMD Navi RDNA2 GPU on macOS Big Sur.
Apple has been using a wide range of AMD Graphics Card from a long time. The good news is with the release of macOS Big Sur, version 11.4, will include the drivers for AMD Navi RDNA 2 architecture lineups, which includes AMD RX 6800, RX 6800XT and 6900XT GPU variants. This means from macOS Big Sur 11.4 and future macOS version, we can have the GPU working, as long as macOS supports it.
With such a good support for AMD GPUs, it's quite easy to get AMD graphics card working on macOS Big Sur 11.4 and later which requires only few steps. The sleep/wake function also works normally without any restarts or crashes. Also you don't need to use any helper cards or IGPU.
Before using this guide, we recommend you to perform a clean installation of macOS.
GraphicsAMD NAVI RDNA 2
KextsOriginal Graphics kexts in S/L/E.
macOSBig Sur 11.4 and later
Compatibility
For more information on GPU compatibility, refer to the thread linked below.
Enabling AMD Navi RDNA 2 GPU
The next step is to enable the GPU. To enable the GPU, you need to add some changes in your configuration. Follow the steps below.
BIOS Settings
The BIOS settings has been provided in a separate thread. For more information on BIOS settings, refer to the thread linked below.
Adding required kexts
The next step is to download the required kexts to enable AMD Graphics. WhateverGreen doesn't works alone. WhateverGreen and Lilu is needed together to work with conjunction in order to enable the AMD Graphics and preventing any errors.
For Clover:
If you're using Clover, copy both the kexts to EFI/Clover/Kext/Others
For OpenCore:
If you're using OpenCore, copy both the kexts to EFI/OC/Kexts. You'll also need to add the kexts entries in Kernel section of your config.plist
  • Do not use WhateverGreen.kext.dSYM, WhateverName.app and Lilu.kext.dSYM
  • Download only RELEASE.zip file.
Modifying config.plist
The next step is to modify your config.plist and add a bootflag to prevent black screen after macOS finishes loading.
For Clover:
If you're using Clover, navigate to Boot section and add "agdpmod=pikera" in Boot Arguments.
For OpenCore:
If you're using OpenCore, navigate to NVRAM section and under Add, add the following changes.
UUIDKeyValueTypeNotes
7C436110-AB2A-4BBB-A880-FE41995C9F82boot-args
  • agdpmod=pikera
STRING
  • Adds boot args which provides several functions.
agdpmod=pikera
  • Fixes Black Screen at boot for NAVI GPUs.
Restarting your System
Verifying your Card
Look for the information of your card under About this Mac and verify the VRAM. For more information of your Card, navigate to System Information and navigate to Graphics/Displays Tab.
  • If you get a black screen, make sure to update your BIOS and switch from Legacy to UEFI boot mode.
  • If your BIOS has CSM option, disable it.
  • If your BIOS has PCI ROM Priority, set it to UEFI/UEFI ROM.
  • If your BIOS has Legacy Option ROMs, set it to UEFI/UEFI Only.
Sample Attachment
The AMD RX 6800 and 6900XT from AMD are used as the example in this guide.
AMD RX 6800
AMD RX 6900XT
Video Demonstration:
Credits:
mooseknuckleboi
recep.67
z390 asrock phantom gamin itx
8700k
6900 xt
11.0.x
  1. OpenCore
where are the kexts? :)
11.0.x
  1. OpenCore
Check the post. It has been updated. The post already mentions "WhateverGreen and Lilu" are the required kexts.
deedee
GA-Z170X-UD3
i7-6700 3,4
RX 580 4Go
11.0.x
  2. OpenCore
  2. MacBook Air
thanks for this tutto, just one thing, i'm not sure rx6700 are op with 11.4
The 6700XT has a different device ID
11.0.x
  1. OpenCore
Yes, that's correct. We're still testing it.
Similar threads
felipe.sntr
