GUIDE How to Configure Memory Settings in OpenCore
Memory
This section provides configuration for your RAM.
OptionsValueNotes
ErrorCorrection
  • 0x01 - Other
  • 0x02 - Unknown
  • 0x03 - None
  • 0x04 - Parity
  • 0x05 - Single-bit ECC
  • 0x06 - Multi-bit ECC
  • 0x07 - CRC
  • Specifies the primary hardware error correction or detection method supported by the memory.
0x01 - Other
  • Sets hardware error correct to other.
0x02 - Unknown
  • Sets hardware error correct to Unknown.
0x03 - None
  • Sets hardware error correct to None.
  • It's advised to set this option to "0x03 - None." Unless you're sure of your memory.
0x04 - Parity
  • Sets hardware error correct to Parity.
  • Sets hardware error correct to Single-bit ECC.
  • Sets hardware error correct to Multi-bit ECC.
0x07 - CRC
  • Sets hardware error correct to CRC.
FormFactor
  • 0x01
  • 0x02
  • 0x09
  • 0x0D
  • 0x0F
  • Specifies the form factor of the memory (RAM). On Macs this should usually be DIMM or SODIMM.
0x01
  • Sets Memory Form Factor as Other
0x02
  • Sets Memory Form Factor as Unknown
0x09
  • Sets Memory Form Factor as DIMM
  • If you're using a PC, use this option.
0x0D
  • Sets Memory Form Factor as SODIMM
  • If you're using a Laptop, NUC, or All Ion One PC, use this option.
0x0F
  • Sets Memory Form Factor as FB-DIMM
Type
  • 0x01 - Other
  • 0x02 - Unknown
  • 0x0F - SDRAM
  • 0x12 - DDR
  • 0x13 - DDR2
  • 0x14 - DDR2 FB-DIMM
  • 0x18 - DDR3
  • 0x1A - DDR4
  • 0x1B - LPDDR
  • 0x1C - LPDDR2
  • 0x1D - LPDDR3
  • 0x1E - LPDDR4
  • Defines the memory (RAM) type.
0x01 - Other
  • Sets Memory Type as Other
0x02 - Unknown
  • Sets Memory Type as Unknown
0x0F - SDRAM
  • Sets Memory Type as SDRAM
0x12 - DDR
  • Sets Memory Type as DDR
0x13 - DDR2
  • Sets Memory Type as DDR2
0x14 - DDR2 FB-DIMMM
  • Sets Memory Type as DDR2 FB-DIMM
0x18 - DDR3
  • Sets Memory Type as DDR3
0x1A - DDR4
  • Sets Memory Type as DDR4
0x1B - LPDDR
  • Sets Memory Type as LPDDR
0x1C - LPDDR2
  • Sets Memory Type as LPDDR2
0x1D - LPDDR3
  • Sets Memory Type as LPDDR3
0x1E - LPDDR4
  • Sets Memory Type as LPDDR4
TypeDetail
  • 2 - Other
  • 4 - Unknown
  • 128 Synchronous
  • 8192 - Registered (buffered)
  • 16384 - Unbuffered (Unregistered)
  • Defines additional memory type information.
  • It's advised to set the TypeDetail to 4 (0x04) - Unknown. Unless you're sure of your memory.
2 - Other
4 - Unknown
128 - Synchronous
Notes:
  • For best performance, we advise you to set the correct memory type.
To find what's your memory (RAM) type, check the guide below.
GUIDE - How to Find Memory (RAM) Type
Reserved.
www.elitemacx86.com
Devices
This section provides configuration of RAM for your hardware if it's not detected properly or has some missing information such as Serial Number. Adding your RAM information here can also fix "can't perform kext scan: no kext summary" error.
To fill out the memory information in OpenCore, follow the guide below.
GUIDE - How to Add Memory Information in OpenCore
Reserved.
www.elitemacx86.com
Note:
Normally, this section requires no modification and will remain untouched.
dominkjg
