- 11.0.x
- OpenCore
Multi Booting Ubuntu and macOS on two separate drives is simple as Multi Booting Ubuntu and macOS on single drive.
(See https://www.elitemacx86.com/threads/guide-multi-boot-ubuntu-and-macos-uefi-on-single-drive.113/)
This guide explains Multi Boot Ubuntu and macOS on two separate drives. Multi Booting on two separate drives is the best way to multi boot. The current release is Ubuntu and macOS High Sierra. Ubuntu and High Sierra will be used for this guide.
This guide is bit lengthy so has been divided into 5 chapters.
The chapters includes.
Step 1: Creating macOS Installation USB
The very first step is to create the Installation USB for macOS High Sierra. To create Installation USB for macOS Sierra, follow the guide here.
Step 2: Creating Ubuntu Bootable USB
Now after creating macOS High Sierra Installation USB, the next step is to create a Bootable USB for Ubuntu. You've two ways to create the Bootable USB either on Windows or Mac.
If you're having a system running Windows, follow the guide here.
If you're having access to Mac, follow the guide here.
Step 3: Copy Post installation tools and Drivers
Insert your third USB Flash Drive and copy the necessary drives for Ubuntu, and tools and kexts for Mac. Once the network is enabled, you can continue with the progress.
So now as you’re having macOS High Sierra Installation USB, Ubuntu Bootable USB and the post installation tools and drivers, so you’re ready to Multi Boot on your computer.
Step 4: BIOS Settings
If you're installing on a desktop with AMI UEFI, the options are simple. For other systems using a different vendor, make sure to set your BIOS or UEFI to Optimized Defaults, and the SATA Mode to AHCI.
Here's a Recommended BIOS/UEFI Settings for Optimal performance.
To access your BIOS/UEFI, press and hold Delete key on your Keyboard. The key maybe different in your case. Refer to your Motherboard Guide/Manual.
Now the next step is to install macOS Sierra. Follow How to Install macOS High Sierra for this guide. Please be sure to follow the appropriate guide as per your build.
Also will recommend to complete each specific install at one time to avoid confusions and hassle free installation.
Once the post installation is completed for macOS, Shut Down your PC.
- 3x USB Flash Drive for Windows, macOS, Ubuntu and Post-Installation
- A working Internet connection to download the files.
- Set Optimized Defaults.
- Set X.M.P. Memory Profile to Profile 1 (Optional, if using a High Frequency RAM).
- Set Windows 8/10 Features to Other OS.
- Set Network Stack to Disabled.
- Set Secure Boot to Disabled.
- Set Intel Platform Trust Technology (PTT) to Disabled.
- Set XHCI Hand-Off to Enabled.
- Set SATA Mode to AHCI.
- Set Internal Graphics to Auto.
- If your system has a VT-d Option, Disable it.
- If your system has Intel Virtualization Technology, Enable it.
- If your system has Serial Port, Disable it.
- If your system has Parallel Port, Disable it.
- If your system has Fast Boot Option, Disable it.
- Save & Exit Setup.
- If you're using a external Graphics Card for your build, such as NVIDIA or AMD GPU, set Initial Display Output to PCIe Slot 1
