- GIGABYTE Z370 AROUS GAMING 3
- Intel Core i9 9900K
- 11.0.x
- OpenCore
Audio is an essential component of any system. Having a HDMI/DP Audio is a great pleasure on Mac. With this feature enabled, you can enjoy watching movies, shows on your big screen television or external Monitor. If having a 4K, the pleasure would be great with the amazing display quality.
The following is a guide for enabling NVIDIA HDMI/DP Audio for Desktops.
Before using this guide, we recommend you to perform a clean installation of macOS.
The method is supported on the following.
macOS/OS X versions:
Before you start
The first step is to download the required kexts to enable audio. AppleALC doesn't works alone. AppleALC and Lilu is needed together to work with conjunction in order to enable the audio.
Downloads
The downloads are available in the Download section of this forum. Alternatively, you can download it from the link below.
For a complete list of supported codecs and the Audio ID, see AppleALC Supported Codecs
Restart your System
After performing all the above steps, restart your system in order to enable the NVIDIA HDMI/DP Audio.
Now you should have a working HDMI Audio
Details :
Sample Attachment
The NVIDIA GTX 650 from MSI, GTX 980Ti from EVGA, GTX 1050Ti from MSI, and Dual GTX 1080Ti from EVGA are used as the example in this guide.
- Supports macOS/OS X versions: 10.14.x, 10.13.x, 10.12.x, 10.11.x and earlier
- NVIDIA Supported Graphics on macOS
- Any of the above chipset
- Any of the above macOS/OS X version
- Working NVIDIA Graphics with correct VRAM and Full QE/CI
- Audio using AppleALC
Before you start
- If you've used any other method such as VoodooHDA, aDummyHDA etc, make sure to remove those files to avoid conflicts.
- If you're using any injector, make sure to remove it.
- AppleHDADisabler, HDAEnabler should be removed.
- If you're using HDMIAudio.kext, make sure to remove it.
- Your Graphics should be working natively with the particular OS X or macOS version and should have no issues.
- Your Audio should be working using AppleALC method. For more information, read here: https://www.elitemacx86.com/threads/guide-how-to-enable-audio-on-your-hardware.99/
Downloads
- Download only RELEASE.zip file.
- Mount your EFI partition of your system drive
- Copy AppleALC.kext and Lilu.kext from RELEASE folder downloaded above.
- Navigate to EFI/Clover/kexts/Other and place the both the kexts to this location.
- If the kext is already present in the directory, replace them with a new version
- Do not use AppleALC.kext.dSYM and Lilu.kext.dSYM
- After placing the kexts, the next step is to rename the audio device and set the device id to enable audio.
- Open your config.plist file
- Navigate to Acpi tab and add the following patch in DSDT, patches section of your config.plist.
Comment: Rename HDAS to HDEF
Find* [HEX]: 48444153
Replace [HEX]: 48444546
4. Navigate to Devices tab in the left pane, and type the layout ID under Inject.
The audio ID depends on the audio codec your motherboard uses. The common layout ID for the common audio codecs has been mentioned in this guide. The tested layout IDs are marked bold and we recommend to use them to avoid any issues.For a complete list of supported codecs and the Audio ID, see AppleALC Supported Codecs
5. Check ResetHDA checkbox under Audio section in Devices pane
6. Save your config.plist
Restart your System
- OS X/macOS does not allow control of HDMI Audio from the system. You need to control it from the HDMI/DP Device.
- If you're having a Pascal GPU (NVIDIA 10xx), there is no HDMI Audio on connected HDMI port after boot. Try all the HDMI ports available. You can also try adapters such as DP/DVI2HDMI or DP to DP.
- For some cards, you may need to swap the port. If the active connection is a HDMI, switching to DP port will have a working HDMI/DP Audio, vice-versa.
- If you're using macOS 10.13.4 and above, and using some old cards, you'll need to use AppleHDA from macOS 10.13.3.
Details :
- Audio Codec
- macOS version
- Copy of IOReg
- Installed AppleALC and Lilu.kext
- DPCIManager/Status
- System Information/Hardware/Audio (All the available Devices)
- System Preferences/Sound/Output
- System Preferences/Sound/Input
- Compress EFI/Clover, exclude the themes folder Do not include complete EFI folder.
Sample Attachment
