- Feb 5, 2022
- ASRock Z490 Phantom Gaming ITX/TB3
- Intel I9-10850K
- Sapphire RX 5500 XT 8GB
- 12.0.x
- OpenCore
Hi there,
Thanks to your help my system is now stable, I would just like to mirror real iMacs and enable iGPU (headless) so that I can use Sidecar etc.
In order to achieve that, do I just add the following to the DeviceProperties section of the config plist :
PciRoot(0x0)/Pci(0x2,0x0) : ig-platform-id : <Data> : 0300923E
and then boot into BIOS and enable iGPU, saving and resetting NVRAM or do you recommend to do it using another method?
Thanks!
Thanks!
