SOLVED BCM4352 not working sequoia
Farouk59
Hi everyone, on Sonoma, everything worked well. So, I updated to Sequoia 15.0 it works well, except the Wi-Fi. I have a Broadcom BCM4352.
Did you root patch the volume?
The kext loading order is not correct. You must block AirPortBrcm4360_Injector.kext by defining the min Kernel.
Ecololical-TAK
