apfs booting problem on LG Gram 17
rdmitry0911
LG Gram 17z990
i7-8565U
UHD620 Whiskey Lake
10.15.x
Hi guys, I have LG 17 Gram 17z990 i7-8565u uhd620 whiskey lake, 16GB ram, 1TB intel nvme, clover 5112 and macos 10.14.5. and 10.15.3 Everything works just fine, but apfs booting. It stuck on ++++++++++++++++++
(see here)
The same apfs disk on another host is booting fine.
My PR:
macos-LG17-2:~ bob$ sudo kextcache -i /
KernelCache ID: 3DE2E40625E2FE8C3D59AAA1180CE962
Kext with invalid signatured (-67050) allowed: <OSKext 0x7ff334b0c9f0 [0x7fffa60698e0]> { URL = "file:///Library/Extensions/Sinetek-rtsx.kext/", ID = "com.sinet3k.Sinetek-rtsx" }
Clover zip file even without most heavy kext is 3.4 MB It is too big to be uploaded here, but I posted a link to the whole folder
Bios pictures are attached as well as ioreg, clover preboot log and bootlog
Ny help would be very much appreciated
  • bootlog.log.txt.zip
  • preboot.log.zip
  • macos-LG17 (2).ioreg.zip
(see here)
My PR:
The configuration is not upto the mark and still has not been fixed. If you have made the changes, provide link to the new EFI.
If you need to start, start here:
I made a new link to efi folder. Inside in log directory I put latest logs and ioreg. I'm using ocquirks instead of aptiomemoryfx as it is much more tunable. And also I did managed to boot from apfs using opencore. I converted my clover config to opencore and it works. The only problem is that every other boot it stuck on still waiting for root device. But nevertheless it is a step forward.
Here are few issues.
The DSDT is not patched as per the guide.
The config.plist is not as per the guide. Use "config_HD615_620_630_640_650.plist"
Still the drivers directory is not upto the mark. Remove the following drivers.
  • AppleUiSupport.efi
  • AptioInputFix.efi
  • NvmExpressDxe.efi
I suggest you to remove the OcQuirks.efi, OpenRuntime.efi and rollback to AptioMemoryFix-64.efi. Make sure you remove the related .plist from the directory.
Remove NVMeFix.kext
Attach a kextcache output.
  • AptioInputFix.efi
  • NvmExpressDxe.efi
Remove NVMeFix.kext
Ok, I'll repatch DSDT, replace drivers and post here the results.
First consider the booting of the Laptop and then the next step should be patching ACPI.
jotascript
