No, no, I didn't set anything special in DaVinci. I just tried the difference between manual and automatic selection of Graphic card, but the result seems to be the same = no success = very poor encoding performance to H.265 ... see image below
Unfortunately there is no possibility to encode via UHD630 (even that iGPU is listed), because it is not selectable and is grayed-out as you can see. This would be a sufficient workaround for me, because encoding via iGPU was quite fast.
BTW it is a free version of Davinci.
Thanks for any help.
Here, uncheck Auto and test Metal and OpenCL. Metal should export fast.
In Resolve, H.265 export is carried out on the GPU. It may simply be that Intel's 10700K H.265's encoder is better than RX 6600XT.
When export to H.265 start in Resolve (free version) processor goes to load and all fans start spinning. So I suspect that dGPU is not being used.
Probably, the main root cause. What's the CPU load when exporting?
Could be mostly related to the free version. Try to export using Resolve Studio.
Hi, I have the same problem. Trying to export to HEVC with Compressor using RX 560 4GB and i5 3470s. Exporting to H.264 took a few minutes and HEVC took a few hours with CPU at 100%. VideoProc says I can encode HEVC and I can use it to encode HEVC on Windows with Premiere Pro. But I don't know why macOS doesn't use my dGPU
Here're my PR files
  • EFI.zip
    EFI.zip
Here're my PR files
Incomplete PR files attached.
Sorry for missing files. Here they are:
Here are a few issues.
- Remove ResetLogoStatus Quirk in ACPI>Quirks section.
- Remove the IGPU Device from DeviceProperties section.
- Set Target to 3 in Misc>Debug section.
- Enable DisableWatchDog, AppleDebug and ApplePanic in Misc>Debug section.
- Remove HfsPlus.efi and use OpenHfsPlus.efi.
Also, it would be better to disable your IGPU from BIOS. If there is no such options, you can disable the IGPU from the config.plist
I've done what you told me. Here it is
I renamed OpenHfsPlus to HfsPlus
Looks good.
Describe your export process and monitoring process.
Looks good.
I tried exporting to 4K HEVC as before and my CPU is at 100% and my GPU at idle
ryusuke17
