I know this is little bit offtopic, but I still don't understeand those 2 separate files. Really the 6th argument make that difference? I mean
DefinitionBlock ("", "SSDT", 2, "KGP ", "DTPG", 0x00001000) vs DefinitionBlock ("", "SSDT", 1, "KGP", "TB3HP", 0x00000000).
What if all content of TB3HP will be moved into DTPG SSDT with 0x00001000?
That is the region of the SSDT.
Attach the complete PR files in one single folder. If the forum has issues in uploading, use Google Drive.
Details:
  1. Thunderbolt Model :- GC-titan ridge
  2. macOS version : 10.15.5
  3. IOReg /Manager/PCI List/DSDT/EFI folder :- Down here
EFI folder
Screenshot 2020-06-10 at 7.07.10 PM.png Screenshot 2020-06-10 at 7.09.28 PM.png
Hope @EliteMacx86 can Help me 😇
Details:
EFI folder
View attachment 2532 View attachment 2533
Here are few issues
  • The config.plist is not as per the guide.
  • Your system has Intel Ethernet not Atheros. Remove AtherosE2200Ethernet.kext
  • AHCI_Intel_Generic_SATA.kext is likely not needed with your system. Remove it.
Ensure that you have correct BIOS settings for TB.
Do you see any TB devices to work with or it doesn't work with Hotplug?
  • Set Thunderbolt Usb Support to Disabled.
  • Set GPIO3 Force Pwr to Disabled.
After setting,
everything doesn't work
Screenshot 2020-06-12 at 4.22.02 PM.png Screenshot 2020-06-12 at 4.23.23 PM.png
ANARKRUTOI
