This is a complete installation guide to install macOS Mojave 10.14 on HP Z620 Workstation paired with 2x 8-Core Intel Xeon E5-2670. The purpose of this guide is to provide a step-by-step guide to install Mojave using Clover UEFI.
Specifications
Motherboard: HP Z620
CPU: 2x 8-Core Intel Xeon E5-2670
RAM: 96 GB DDR3 1600MHz
Graphics: AMD Radeon RX580
Monitor: LG
SSD: WDC Blue 1TB SSD
Ethernet: Intel 82579LM
Audio: Realtek ALC262
Summary
What's works?
Graphics ✔
Ethernet ✔
HDMI (Audio)✔
Power Management ✔
iMessage ✔
FaceTime ✔
iCloud ✔
USB 2.0, and 3.0Ports ✔
Not working
Everything works so far.
Bootable Media Creation
To create a Bootable media for Mojave, follow the steps below.
1. Insert your USB Flash Drive and open Disk Utility. The Disk Utility is located at /Applications/Utilities/Disk Utility
2. Select your USB Flash Drive in the left pane and click on Erase button, at top.
3. A pop-up will appear.
4. Under Name type USB
5. Under Format select Mac OS X Extended (Journaled)
6. Under Scheme select GUID Partition Map, and click on Erase.
7. When done, click on Done.
8. Launch terminal, located at /Applications/Utilities/Terminal.
9. Copy and paste the following sudo command in terminal.
10. Enter your password
11. Press (Y) to confirm and then press enter key and it will start to erase the disk and will create macOS Bootable USB.
Once the process completes, close the terminal. The USB Flash Drive will be renamed as Install macOS Mojave.
Install Clover Bootloader
The next step is to install the Clover Bootloader to your USB Flash Drive.
1. Download Clover EFI Bootloader.
2. Extract the Clover EFI bootloader installer package and right click on the .pkg file and select Open
3. By default, the Clover Bootloader will select the system drive i.e Macintosh HD. Simply click on Change Install Location and select your installation Drive i.e Install macOS Mojave.
4. Click on Customize and configure the following settings.
6. Confirm the above options and click on Install. When promoted, enter your password. The clover bootloader will be installed to your installation drive.
7. Once done, simply click on Close
After installing the Clover bootloader, the EFI partition should be mounted on your Desktop.
Now you’ve successfully installed clover and the required drivers on your USB.
Placing required kexts
In order to boot into the installation, you need to place the necessary kexts. Follow the guide below to place the necessary kexts.
Downloads
Navigate to /EFI/CLOVER/kexts/Others/ and place all the 6 kexts (FakeSMC.kext, VoodPS2Controller.kext, USBInjectAll.kext, Lilu.kext, WhateverGreen.kext and VoodooTSCSync.kext)
Preparing Post Installation Tools
The next step is to place the required tools, kexts to the another Flash Drive which will help you in the post installation.
1. Insert your another USB
2. Format the USB with the following parameters
Under Name type Post Install
3. Copy the important tools such as DPCIManager, Clover Configurator, IOReg, MaciASL.
4. Copy Intel 82574L Ethernet kext so that you can have a working Internet connection on your build.
When done, simply eject your second Flash Drive.
Copy the Config.plist
I've written a guide to create a config.plist. Follow the guide below
www.elitemacx86.com
1. Download the config.plist file from the above linked guide.
2. Open the config.plist file using Clover Configurator and do the following edits.
Go to Acpi tab and include the below patch.
3. Go to Boot tab and select "npci=0x2000"
4. You need to set the SMBIOS to MacPro6,1. The rest will be same as in the config.plist sample.
UEFI Settings
To access your BIOS/UEFI, press and hold Delete key on your Keyboard and then set the following.
Set Optimized Defaults.
Set Intel(R) VT-d to Disabled.
Set VGA Priority to Offboard.
Set Serial Port to Disabled.
Set SOL Serial Port to Disabled.
Set Boot Mode Select to UEFI.
Save & Exit Setup.
Installation
Follow the steps below for the installation.
1. Turn on your PC
2. Press F12 to enter boot menu.
3. Select your USB Flash Drive with the UEFI prefix and press enter to boot.
4. When at Clover screen, select Boot macOS Install from Install macOS Mojave.
5. It will take couple of minutes to boot into installer screen. Once you reach the installer, select your preferred language and continue.
6. For a fresh installation, you must erase the drive you wish to install on. Follow the steps below to erase the destination drive.
7. On top, click on Utilities and then select Disk Utility.
8. When at Disk Utility, click on View and select Show all Devices.
9. Now select the SSD.
10. Make sure that you don’t select partition, select the Drive and click on Erase button.
Under Name type Macintosh HD.
Under Format select APFS.
Under Scheme select GUID Partition Map, and click on erase button.
Close Disk Utility
11. Select Install macOS and continue with the options.
12. Now select Macintosh HD and click on Install.
13. Upon completion, the system will automatically restart. The system may restart few times to complete the installation.
14. If the system restarts, select Boot macOS Install from Macintosh HD.
15. After installation, boot it using USB, but this time select Macintosh HD.
16. The first boot maybe slower as the caches are not build yet. Once the caches are built, it will boot normally.
17. When you're at the welcome screen, continue with the basics options such as Keyboard setup, Network, Computer Account and Privacy settings.
Now the installation is complete, but the drive isn't bootable yet. You need to configure the Post Installation
Post Installation
Now, configuring the Post Installation
The post installation is required to achieve the fully system functionality.
Typically, the post installation includes enabling boot from the system drive, Graphics, Network, Audio, and USB.
Boot from System Drive
Mount the EFI Partition.
Be sure to mount both the EFI partitions of your Hard Drive and macOS Sierra Bootable USB. Both the EFI partition of your Hard Drive and USB Flash Drive will be mounted on your Desktop.
Assuming that you’ve mounted your EFI Partition, continue the following.
1. Open your EFI Partition of your Hard Drive.
2. Select EFI folder and then move to Trash.
3. Now open your EFI Partition of your macOS Sierra Bootable USB.
4. Now copy the EFI folder to your EFI Partition of your Hard Drive.
By using this method, You’ll able to install Clover Bootloader automatically to your Hard Drive.
This build is having AMD RX580 Graphics Card. The GPU works out of the box.
Network
The motherboard uses Intel 82574L Ethernet Chipset. All you need to do is to install the kext and reboot the system in order to activate Ethernet. The downloads for Intel Ethernet is available in the downloads section.
Audio
The motherboard uses a Realtek ALC262 Audio Codec.
There are several ways to activate audio. I'm using Apple ALC to enable audio on this build. Follow the guide below to enable Audio.
www.elitemacx86.com
There are two USB Chipset used by this motherboard. The default Chipset from Intel and the ASMedia for USB Type-C and Type-A. The ports works OOTB. All the USB ports are activated by default.
Use the guide below and add the patches to your config.plist.
www.elitemacx86.com
Save your config.plist file
CPU Power Management
Now, the final step is to implement CPU power management for maximum performance.
Follow the guide below to implement the CPU power management for X79 motherboard.
www.elitemacx86.com
Restart your System
After completing the post installation, restart your system.
Specifications
Monitor: LG
Summary
What's works?
Graphics ✔
Ethernet ✔
HDMI (Audio)✔
Power Management ✔
iMessage ✔
FaceTime ✔
iCloud ✔
Not working
- Install Clover for UEFI booting only
- Install Clover in the ESP
- Themes: Select any
- Drivers64UEFI: AptioMemoryFix-64 and ApsDriverLoader-64
- Do not forget ApfsDriverLoader-64 to install.
- With the use of AptioMemoryFix-64, you don't need to use EmuVariableUefi-64.
- Do not install AppleKeyFeeder-64 from Drivers UEFI.
Downloads
- FakeSMC.kext: https://github.com/RehabMan/OS-X-FakeSMC-kozlek
- VoodooPS2Controller.kext: https://github.com/RehabMan/OS-X-Voodoo-PS2-Controller
- USBInjectAll.kext: https://github.com/RehabMan/OS-X-USB-Inject-All
- Lilu.kext: https://github.com/acidanthera/Lilu
- WhateverGreen.kext: https://github.com/acidanthera/WhateverGreen
- VoodooTSCSync: https://github.com/RehabMan/VoodooTSCSync
- Use the kext from Release folder.
GUIDE - Creating a Basic Config.plist file for booting macOS on Intel Desktops (Clover)
By following this guide, you'll be able to create a basic config.plist for booting macOS on Desktop. The config.plist is a system configuration file for the Hackintosh and allows to boot macOS. Without a config.plist, no machine can boot into macOS. A basic config.plist file is automatically...
www.elitemacx86.com
Comment: Rename EUSB to EH01
Find* [HEX]: 45555342
Replace [HEX]: 45483031
Comment: Rename USBE to EH02
Find* [HEX]: 55534245
Replace [HEX]: 45483032
UEFI Settings
Save & Exit Setup.
Installation
1. Turn on your PC
Close Disk Utility
Post Installation
Network
Audio
GUIDE - How to Enable Audio on macOS [Clover/OpenCore]
How to Enable Audio on macOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers the implementation of Audio on macOS using Clover and OpenCore. By following this guide, you'll be able to enable Audio on macOS using Clover or OpenCore Bootloader. This guide can be used for...
www.elitemacx86.com
- Use layout id=11 only. If you use any other layout, there maybe distortion with the Speakers or the Headphones.
[Fix] USB Port Limit 10.14.4 by ©PMHeart
PMHeart found a way how to fix the USB Port Limit Drama with this 3 KextsToPatch Entries. Just add them to your Config.plist and everything is great again. All credits goes out to @PMHeart PS: Personally I didn't check them out... Since I don't need them all because I use a custom USB Kext on...
www.elitemacx86.com
GUIDE - How to Enable Intel CPU Power Management on X79/C606 Motherboards [Sandy Bridge-E/EP and Ivy Bridge-E/EP]
How to Enable Intel CPU Power Management on X79 Motherboards [Sandy Bridge-E/EP and Ivy Bridge-E/EP] This guide covers the implementation of Intel CPU Power Management on X79/C606 chipset based Motherboards. This guide is supported on Sandy Bridge-E/EP and Ivy Bridge-E/EP CPUs lineup, up to...
www.elitemacx86.com
Restart your System
