ASUS PRIME Z690M-PLUS D4 - i9 12900KF - 128GB RAM - AMD RX 5700XT - Thunderbolt HotPlug - OpenCore
Sounds good!
Its been months now. Still running perfect on this Hackintosh OSX Big Sur. Dont really want to upgrade the OS due to everything works lol.
I do have a very small issue. Sometimes system will lag, still plenty of ram but all of the sudden i can not use bluetooth or usb devices. I am forced to hard reboot. Is there a way to resolve this? Potentially this would be like a kernel issue correct?
Could be possible. Attach the EFI to check first and the problem can be diagnosed further!
Hey I have about the same specs, but I have a ASUS B760M-AYW WIFI D4 II motherboard, does this setup work with this motherboard? And would it work with macOS Tahoe?
@1coolappdad Your EFI is not as per the guide.
You should consider mapping the ports first.
Please create a separate thread.
Once I changed the efi Settings and rebooted, entire system went a bit haywire. I just shut it down for a while but now won’t come back on. Think power supply is shot, no biggie however… I pulled my SSD and tried to get some files I need for Monday and it won’t read on any system. Think the SSD got fried?
New thread here
To answer my own question, yes I am able:
Thanks for the guide!
Do you happen to know if i used a 790 board would my build come back to life? Figured out my board is fried, just trying to get back setup as quick as possible
oneinchashh
